mikrotik issues singal issues
n1ghtwalk3r
I am building my own isp it was just to make a trial of the MikroTik board well I got more issues then just the net I bought two brand new sector antennas now almost 2 weeks ago when I was trying the MikroTik when it was working fine before it blow up cause of high voltage from the power suppliers in Malawi I could pick up over 100 networks when I scanned through the MikroTik board now I can only pick up 10 networks it seems the sectors are not working or the pigtails or coaxial cable or either the wifi cards how do I solve my issue when I broadcast both sectors I get
00:0C:42:26:3F:8A iConnect_1 WPA -80
00:0C:42:26:3A:3B iConnect_2 WPA -78
before I was getting -50 dbm on iconnect_1 and on iconnect_2 I was getting 70 dbm cause of iConnect 2 I had to keep removing the MikroTik board and coaxial cable to fix them but has made it worst how to I find out what the problem is from these items
MikroTik board or wifi cards
Pigtails
Coaxial cable
Or the sectors them self.
I tried using a nanostation as the radio on iconnect_1 and it did not broadcast at all at list the MikroTik board broadcast at 80 dbm.
Please help am stressed that my sectors might be burned I put allot of money in them.
What do I do?
It seems like just the cards are broadcasting and not the sectors their like 30 meters away and 24 meters high of ground. And they giving signal in 70 dbm very bad
Oh one more thing all my pigtails were broken I soldered them back on but when I test on both ends with conduit they show sum voltage
replace the pigtail with a new one. a Soldered on just aint as good as a new one.
Are you in Malawi?
How many ppl are going to connect to the sectors?
Mikrotik is one of the best routers i've seen.
Using one for my WUG link. :D
i can t get any more thhats why i soldred them i can t get good brand new pigtales this place is hard to get stuff at cheap and good price a pigtale would be going at about 5 thousand kwacha each thts alot u knw where as from SA cost 1500 but am guessing the boards has issue aswell
Wow, I'm going blind!
Did not see one punctuation mark!
Wait, I can see mine....
