in the Web interface, do the following:
- Go to Advanced Setup -> WAN
- Remove all existing WAN interfaces
- Add a WAN interface
- Port=0, VPI=8, VCI=35, Service Category=UBR without PCR, Unselect Enable Quality of Service
- Select PPPoE over Ethernet (PPPoE) & Encapsulation Mode=LLC/SNAP-BRIDGING
- Enter your username ([email protected]) & password, Leave Authentication mode=auto, Leave Obtain default gateway automatically selected, Select Keep alive PPP connection, Leave Dial on demand unselected, Leave Static IP address unselected, Select Bridge PPPoE Frames Between WAN and Local Ports (this is for half-bridging / PPPoE Relaying / PPPoE Passthrough), Leave MTU=1492
- Select Enable NAT, Select Enable Firewall, Unselect Enable IGMP Multicast, Select Enable WAN Service, Set Service name to something descriptive like: PPPoE_Mweb
- Save & Reboot
Now under Device Info, all the fields should be filled in!
And under Diagnostics, everything should PASS, except for the 2x ATM OAM F5 tests.
* Update:
With regards to your telephone connection: how did you connect the telephones & ADSL to the Telkom line?
Both the ADSL router/modem and the telephones MUST be connected via a (micro) filter to the Telkom line!
You can get a splitter filter (where you can plug in both a telephone and ADSL modem) from Telkom shop for like R42 or something like that.
