Neotel Network Problems
Neotel customers dogged by network problems, but no official comment from provider
Tell me about it. Got a R399 Neoconnect Prime package 2 weeks ago and the fastest I've gotten is about 20kb/s. It's insanely slow, and I've 100% coverage, I'm in the center of Cape Town CBD.
I heard from the Neotel rep from myadsl (he called me) and explained that the network has grown to fast hence the over load.
If you're gonna give uncapped 2.4mbs for R999 then you better make sure you can handle the customer influx. If it's an alternative to Telkom, then bus loads of new business should have hit them at once.
Ai ai ai.
For sure, they do just 'die' don't they! For now I'm lucky and have an alternate resource for DSL here so I'm using the Neotel as a phone primarily and as backup internet incase something happens.
The battery life on the Neotel phones is amazing, if the power goes out then I can get a days worth of net time, but my laptop wont last that long![]()
If they give you an ETA on when it can be fixed then if I was you I'd get a second hand 1.8mbs 3G card for about R500 and use prepaid 3g, buy a 500mb bundle for R189 and use that to surf with. Good side to it is, you'll have 3G for a backup incase this ever happens again
It is that bad that I don't even surf on it (Neotel), unless I really have to, I use DSL in the meantime![]()
Try this, a trouble ticket open from Oct08 for poor signal and drop in speed - still open till Dec08 - then closed 'cos they said they will issue and external antenna despite my insistance this is a tower issue. Up to now I still don't have this antenna.
Since Jan09 it skids downhill faster than Shabir Shaiks parole hearing, with the introduction of Neoflex, I'm barely seeing more than 40kbs. and they are still taking my 1000bucks a month.
Thanks to mybb for highlighting our plight, maybe there could be some urgency from their side to have this fixed.
