I believe the only real difference is that Q35 has LDAC support.This or Q30
Other than that, they are very similar and sound or performance differences are negligible.
I bought the Sony WH1000-XM4s after putting it off for a long time (always told myself they're too expensive for a pair of headphones).
These things are magical. Used it while sitting at the same table as my ex-SO, who used to have meetings all the time. Really helped with my concentration and productivity.
That being said, I tried on a pair of Anker Q45s (at a duty-free). For the short amount of time I had them on, they felt the same to me as the Sonys, so maybe look into them as well.
Gave these a look as well. Think I tried them on at one point and preferred the feel of the Sonys. Also, they were much more expensive.Was thinking of going for Sony again for my morning commute (pre-COVID) but decided to treat myself to these instead:
Global Contact Hub
Find customer support services and authorized resellers available in your location.global.bose.com
Don’t even realise I have them on, and hear nothing from the world around me with the NC activated.
Global Contact Hub
I have the Sony XM5s and the Bose QC 35 IIs. The NC is better on the Sony but the QC IIs are a little more comfortable. Still the Bose sound is Bose, it's a bit muffled. The Sony's have better sound quality, less distorted and more "audiophile" friendly. For movies Bose is OK though. If you are a music purist, go with Sony.
Previous headset was Sony (not XM5s, mind you), and I prefer the Bose all round in comparison.
I need noise cancelling headphones for work.. My wife is forever shouting when she is in a meeting with her headset on and my current headset has zero noise cancelling..
The biggest concern is noise cancelling but it needs to be budget friendly and have somewhat decent sound..
I don't have a specific budget in mind, the cheaper the better of course..
Specifically from Takealot?Anyone tried a noise cancelling over ear headphones set from Takealot that they can recommend? Budget is R6000 @SauRoNZA
The Soundcore Q45 is good and less than half your budget.Anyone tried a noise cancelling over ear headphones set from Takealot that they can recommend? Budget is R6000 @SauRoNZA
Highly recommend Sony's XM3 / 4 / 5 whatever is on sale. Absolutely THE best.Anyone tried a noise cancelling over ear headphones set from Takealot that they can recommend? Budget is R6000 @SauRoNZA
AirPods Pro have amazing noise cancelling but not over-ear and I do find it uncomfortable to wear them for too long.AirPods Pro.
Or increase budget and get AirPods Max.
Other headphones don’t exist.
Its pretty damn good for anything and most things. Some sounds will be much softer. It works the most bestest if you have some white noise or music playing.Nice nice, I don't mind upping the budget if I have to
Does the noise cancelling only cancel out certain frequencies for example engine sounds, etc?
Or will it also cancel out the sounds of a noisy co worker that sounds like that cop from Police Acadamy?
