Hello.
I want to replace the 12V 7Ah lead acid battery that I use for my alarm system and electric fence with two LiFePO4 versions.
SecuriProd sells a 12.8V 7Ah model that they say is a drop in replacement. I am just concerned that, although this model may last longer (life span) than the lead acid variety, it will still take heavy knocks due to stage 6+ loadshedding. I then wonder whether it makes sense to pay so much more for it (R800 vs R350).
My question is this: would the 12.8V 20Ah model make more sense? It is more than double the price but I figured that the higher capacity will prolong its life because it won't be emptied as often, thereby reducing costs in the long term.
I am not very clued up on electric theory so I'd really appreciate some help. Firstly, does it make sense? And would it be plug and play or whould I need to install some kind of adapter for it to work? I know it is physically bigger as well, but I can deal with that using an extension.
Here is a link to the larger model: https://www.makro.co.za/home-garden...v-20ah/p/c77cb036-8458-4192-92ec-97ff26553ac3
