Ok I figured instead of derailing the general S3 thread constantly, we can have a issues thread. If anyone highly objects it can be deleted
So I had some serious battery issues from day 1 and with the help of Krypt0n1te managed to resolve my problems. I was seeing a massive drain over night whilst on standby. Essentially I managed to fix this by getting 2 apps, BetterBatteryStats and Battery Monitor which gives you a better understanding of what is chewing the battery and how much drain is going down. I essentially nailed it down to 2 things. Other than the power saving on etc, I switched off key tones, touch sounds and screen lock sound. I also turned off the ripple effect on the lock screen. Also make sure to set Wifi to Never stay on when sleeping. Just doing these things alone have made a massive difference to my battery life. I have managed to get 1day 7hrs out of my battery and I am on 29% charge.
I also disabled some bloat ware in the background, no idea what some of it does, but I haven't had any issues thus far. Some people may want to keep these on if they use the features, but for me I don't need most of them.
I disabled:
All Share
BroadcomMEMsService
ChatON
Exchange services
Samsung Push Service
Video Hub
Now some of these might be important for certain features to work properly, but as I mentioned I have no noticed any issues. If you have any others than can be disabled let us know in this thread please.
Lastly I have heard a lot of people complain about the high data usage on the S3. I installed Onavo and it seems to aid a fair amount. It creates a VPN connection which some how by magic decreases your data usage. Maybe someone can explain the mechanics behind this, I am not to sure how it works. It also allows you to monitor usage and what apps are using your data. Very handy little app.
Again a shout out to Krypt0n1te for his assistance, I am sure if anyone has issues he can add some value.
I disabled:
All Share
BroadcomMEMsService
ChatON
Exchange services
Video Hub
