Settings >> Mobile Data
robhob
G'day!
Anyone see this before:
I'm referring particularly to the Mobile Data menu option. This is one of a number of iPads supplied by DigiCape. It won't connect to the internet on 3G. My iPad says Cellular Data.
Could this be a Verizon model?
Any ideas?
Best place to check is the back of the box it came in it will say gsm or ucdm or what ever the version one is! Iq so had to make sure I got one that works on our networks! I doubt divi ape would be importing the wrong units though! My menus look the same as urs though! My only suggestion is to try plug it into the pc and see if iTunes finds an update for the Mtn network settings, mine did when I put an 8ta sim in!
My iPad 2 3G bought from IC also say cellular data
