Inspection box? Havent seen one but my house very old.You'll also find that often your neutral is passing through the inspection box above the switch on it's way to the light fixture
Pulled neutral wires and installed 2 qualitel smart light switches.Inspection box? Havent seen one but my house very old.
In tuya based Smart life app, option of association. It seems software based only but not sure how it works in practice.Maybe get one and check that it covers the opening left by the old switch. The Sonoff's are slightly smaller than the old fashion light switches.
Other than that, nothing really. I bought mine from Banggood where they were nice and cheap. I also picked up a couple from Smartkit.
Where you may possibly need to get creative is if you have a 2way switch somewhere. I.e two switches that control a single light. There are things you can do about this if you flash them with Tasmota like utilizing long press actions etc.
Mine qualitel ones, illuminated at all times. Blue is off and red is on.I had wondered about that before I got the switches.
Now its second nature to just press the right area, the switches can also be illuminated at night if you set them that way.
"... Yes, there are a few…(read very, very, very few) switches that don’t require a neutral, but those will limit you to incandescent only. For those of us using LED, Fluorescent or some other energy efficient bulbs under 20w a neutral is REQUIRED!"
To which live and neutral etc is 2nd switch linked. I understand it doesn't have to be linked to same light but it the 2nd light switch must have neutral at least to be powered?
Then surely most would opt for this as it would be easier than switches requiring neutral?Not true. The ones that don't require a neutral wire can work with bulbs under 20W. The switches are supplied with a capacitor that is placed across the light fitting as per your pic. I have no neutral switches in my home, all on LED lights, and they work perfectly with the capacitor fitted.
Dont know any but are you referring to Sonoff light switches or the basic switches connected to light switches or outlets etc?Any recommended electricians familiar with sonoff in the Randburg area?
Would need to start from scratch.
If bulk buy directly from qualitel. Quick shipping, virtually overnight. Shipping worth it if buying in bulk.So I got this to test out:
Takealot.com: Online Shopping | SA's leading online store
South Africa's leading online store. Fast, reliable delivery to your door. Many ways to pay. Shop anything you can imagine: TVs, laptops, cellphones, kitchen appliances, toys, books, beauty & more. Shop the mobile app anytime, anywhere.www.takealot.com
Got it today and installed, so far so good. Works well with Google home/ and Google Assistant.
Timers, remote switching. Glass touch face.
Was able to get it to work without pulling Neutral wire and just use the earth wire instead.
Only one issue I had is it was a bit of trouble to set up with the app, but otherwise it's fun not needing to stand up to switch lights.
I will get more to replace the other switches.
The earth is for protection and not supposed to be used as a return path. All you needed is 1 fault. Do yourself and your family a favour and pull a neutral.So I got this to test out:
Yeah, I should remove that part of the comment, was only temporary for testingThe earth is for protection and not supposed to be used as a return path. All you needed is 1 fault. Do yourself and your family a favour and pull a neutral.
