I live on the "edge" of Telkom LTE reception and get 1x bar of signal inside my home.
I'm really impressed with quality of Telkom LTE and ideally would like to use it.
Can an antenna really give you good quality LTE if you have 1x signal bar?
Something like this: http://www.antennas.co.za/Products/ProductDetails?code=358
I don't want to spend money on the "best" antenna only to get 3x signal bars but poor network quality.
Some users suggest that most of the signal is "lost" in the cable and it doesn't really help.
Anyone with a Poynting installation achieving good speeds / quality?
