Top PCI E16 port broke
Kayoss
Hi all,
My top PCI Express 16 port broke when taking out my GFX card this afternoon and bent all the pins (the plastic part came off).
If I run my GFX card in the second PCI port will it run at x16 or x8? And if it runs at x8 will this make a noticeable difference when pushing the Gfx card (VR Gaming with SS)
Mobo: MSI Z97 Gaming 5
GPU: 1070
I think you can set the 16x port in the motherboard.
I'd be more worried about a short nuking your whole system when you turn it on than that.
I turned it on briefly and it seemed to work.. Resolution was terrible and then seemingly reverted to normal.
I guess none of those needles are making contact with one another, but I am worried going forward. Presumably it isn't something that can be repaired?
The msi website states the following for the mobo :
3 x PCIe 3.0 x16 slots, (support x16, x8/x8, x8/x4/x4 modes)
So it's a bit ambiguous as to whether having the second PCI express 16 port is at x8 or x16
No, it is quite simple - it is configurable to x16 for the top slot, or x8 + x8 (top and second) or x8 top, x4 second, x4 third.
Thanks, but does that suggest that a single card in the second slot will still be able to operate at x16 or at x8 only. Or that it's only limited to x8 when in sli?
