Using current router for Fibre
#1
I have just ordered fibre with Mweb on Openserve and they give a free router. However its Wifi speed tops at 40mb/s which tells me the thing is probably gonna suck at everything else.
So I have a Netgear DGND 4000 and was wondering if it supports fibre through the grey ethernet port which I think is a wan port since it is separated from the rest which are all yellow.
ponder
#2
Yes you are good to go. The grey ethernet port is indeed a wan port.
delonk
#5
Hi,
Were you ever able to get the DGND 4000 working with the WAN port? If so, would you please share the settings?
