Wifi antenna
Silver-0-surfer
CPT
Hi.
Just a quick question(hopefully)
If I take my AP at home, which has a removable antenna & then I put in a big outdoor omni antenna, will that work?
Will the AP have enough power to actually use the omni?
Hopefully that actually makes sense...
i'm a bit noobish:erm:
yep it will work try keep your antenna cable short as possible to avoid losses
well I have that Mega 105 from telkom and a linksys, my friend said I could have his monster antenna so I just wanted to know if it would work before I go out and buy the connection converters:D
edit: okay question 2, I have a wireless USB card that has a external antenna, could I insert this antenna on a wireless card? very unpractical I know, but will it work?
if the connector plugs unto the card. Maybe you should just buy a pci wifi card or get a wigi router from the computer store.
