Wifi UPS cables
jakalas
Hi
I'm looking to buy a Wifi UPS to hopefully power 3 devices (modem & 2 wifi routers). My problem is the distance between the devices and I would probably need about 2 x 20m cables for the furthest devices.
Can I purchase cabling that will fix this problem ?
Hi
Yes, cables and DC jacks.
Just use network cable way cheaper for that distance than those round 2 core wire normally used for these DC cables and if they need to run outdoor use outdoor network cable :)
