Like the OP: Does anyone know where I can find one of these cables that has the mini-USB plug on one side and two standard USB plugs on the other side, to provide the extra power?
Seems like my cable is starting to go faulty.
Does makro, incredible and game stock these?
If your USB port is 2.0 then one cable should be sufficient. If it's USB 1.0 then you'll most likely need the 2-into-1 splitter. What you really want is a nice USB 3 port which can provide 900 mA, versus USB 2's 500mA
Thanks guys, I would prefer if I can just go to a store and buy one instead of online. Perhaps matrix and hi-fi corp will have them. Makro only have the ones with one usb...
