Afrihost ADSL connecting problems
That's pretty crappy for a 6Mbps line. Do you normally get better speeds? Let's let the network settle down, but please PM me if this doesn't improve :(
Speed has improved!
Test conducted on Tue Oct 16 2012 20:40:50 GMT+0200 (South Africa Standard Time)
Download Speed: 5306 kbps (663.3 KB/sec transfer rate)
Upload Speed: 373 kbps (46.6 KB/sec transfer rate)
Latency: 27 ms
Same here, very weird. Ping to Joburg is already bad, like 40ms or so ... and ping to CT is even worserer.
I can only assume it will be the moment. IPC is running via JHB. So when you ping something in JHB, it goes to JHB. If you ping something in CPT, it will go to JHB then back to CPT.
speed test results for a 2mb line :
Test conducted on 16 October 2012 10:46:08 PM
Download Speed: 123 kbps (15.4 KB/sec transfer rate)
Upload Speed: 124 kbps (15.5 KB/sec transfer rate)
Latency: 43 ms
