If i stick the sim in my LTE mifi , will i get LTE?
I recently got a LTE mifi ...
When i get my afrihost setup, you think MTN has allowed them on the LTEnetwork?
If i stick the sim in my LTE mifi , will i get LTE or just a strong fast 3g ?
I believe that Afrihost has said that the preorder sims are not LTE compatible, might want to check with Afrihost.
I put this sim in my E3276 modem, and it picks up LTE MTN. I just cannot join the network.
Works fine on DC-HSPA+ and Edge
http://www.speedtest.net/my-result/2928011219
The SIM cards that went out on Pre-Order are not LTE ready, and they will not be able to be LTE capable even after launch. We'll have new LTE enabled SIMS at launch on 3rd September.
It may be your device picking up LTE networks, not the SIM itself.
Yeah, the device picks up LTE but obviously the SIM isn't authorised. No biggie, I'll cancel the SIM I got with this device and get another one when the LTE ones are out![]()
Awesome. Should be an easy process in ClientZone![]()
@AfriMan can you confirm if some users who pre-ordered received LTE mifi devices. If that is the case then awesome unless I am not reading between the lines.
No, none of the pre-order SIMS were LTE enabled, and the MiFi cannot do LTE - they're all the same.
The only LTE SIMs will be available after launch (3rd Sept) - our network is LTE ready though
now if only I could get LTE coverage
MTN's LTE coverage in Durban is spotty like a teenager with acne.
So if we want LTE we have to get new sims after 03/10/2013 I wonder how much a sim swop will be
Afriman confirms they are taking over mtnhaha just joking
