Connection Problems on Mweb Uncapped
NomNom
Auckland, New Zealand
Hi there
Since this morning there have been connectivity problems on my friends 3mb uncapped. Most if not all websites don't fully load and when I try to download something the download doesn't finish, it would download to about 99% then randomly timeout for no apparent reason. We have ruled out the possibility of there being a computer fault somewhere by using two completely different computers. Also some websites have Connection reset problems, when I try to reload them they show a connection reset problem again, in a continuous loop.
An example of a website that doesn't load/work correctly is:
http://speedtest.net/
http://news.sky.com/home/
Is anyone else having issues?
Help please :(
Hi Everyone,
All your international issues are noted. We are currently investigating the root cause of the issue.
Please send me all your ping & tracert and the area you from as it will help in the investigation.
Your patience is much appreciated.
Kind regards,
MWEB Guy
Hi Everyone,
Kind regards,
MWEB Guy
Source? thank you :)
EDIT: never mind found it :)
Hi there
Help please :(
Speedtest is usually throttled when they have speed issues. Wouldn't want you to have proof now would they :D
Hi there
Help please :(
Have the exact same issue. Tested it at home on a normal uncapped account and on a business uncapped account at two different locations (Bellville, Tableview) with multiple computers and they all have the same problem.
Started some where during Sunday evening if that helps Mweb guy.
It's looking a bit better now as some stuff that didn't want to connect since yesterday are working again. But I'll first check if it completes properly.
