beeskuiken
##Resolved## FNB Connect Slow data speed
I just got my FNB Connect SIM and I have almost non existing data speed.
I tested it in different locations, but no luck.
According to speedtest.net its as low as 0,01Mbps!!! See below> (on Vodacom I get more than 40Mbps)
http://www.speedtest.net/my-result/a/3626640232
http://www.speedtest.net/my-result/a/3628353854
Signal strength seems ok most of the time. Sometimes it shows the 'R' for roaming, but not always.
The data icon is an 'E' as opposed to the 'H+' that I'm used to. According to FNB's coverage map, I should have LTE coverage.
According to the speedtest results, it seems as if they are using the Cell C network?
I did log a call - still waiting for response.
Is anybody experiencing the same?
Thanks,
p
Thanks,
p
