hornbill81
I have even gone as far as to put my phone in ultra battery saving mode and gpsd still was the highest consumer of battery. Samsung S5 on cell C network.
switch to 2g and reboot that's what I did two months ago and haven't had this problem since.
The above works, the reboot is required for it to work.
GPSD was on 35% on GS4 (CellC) - after enabling GSM only the screen is at the top of the battery list. I think my S4 battery condition has been affected by all the drainage of the past few days - it discharges much quicker now than a week or so ago? I do not have a Samsung account therefore no remote controls running...
Are Samsung aware of the problem?Agree. There seems to be no response from Cellc and they are not logging our calls. Did u try to o log a call? Anyone with a contact inside Cellc?
You indicated that this problem occurs on other networks as well. Do they also have free WhatsApp?I still think its their free WhatsApp causing it
I have been following this thread from the beginning.See my previous comments, I put in a Telkom sim in my phone and the problem is gone!
I've gone as far as switching off my data and GPSD is still draining my battery.
This issue appears to have occurred after software update to 4.4.2 (kit-kat) for the Samsung S4. We are still investigating the root cause issue. *DM*
