The built in charge is usually sufficient heyI have a rct 2000va ups . think its got a 10 amp built in charger . not 100% sure. Should that suffice. Probably take 10 hours
Ok, so I used it for the first time last night. It was on 78% when I started using it. Is this normal for batteries that is brand new.
I had my 32" tv, surround sound, modem, media player and 3 lights on for 2 hours and used about 10% of the batteries. I put it on charge at 8h30pm until 6h30 this morning, meaning it charged about 30% in 10 hours on the rct charger. I did not want it to charge the whole day while I'm at work, so I disconnected when it was on 95%.
Which I could get a charger that can automatically switch off when charging is finished
Lead Acid self discharges relatively fast, so yes, it is normal that it would be at 78% if it hasn't been charged in a month or so.
Switching off charge before its finished is a no-no you're going to kill the battery fast if you are doing that, as the capacity will be reduced.
You really need a decent charger for Lead Acid, as its the special needs child of the battery industry.
You need bulk charge, float, absorption charges, desulphation regimens..
Lead Acid likes to be charged to 100+% on a regular basis to avoid sulphation - once a month or so.
Charging from 80% - 100% usually takes a lot more power going in that will come out too, as its least efficient at that range.
Peukerts law.. You'll lose about 35% efficiency going in / out of Lead Acid.
Suggest read some of the info here:
http://www.sustainablepreparedness.com/index.php/blog/batteries-101-depth-of-discharge
http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery
http://all-about-lead-acid-batterie...amentals/peukerts-law-and-exponent-explained/
Thanks lsheed_ct. Can you recommend a decent charger that does not cost an arm and a leg. What would you suggest iyho.
I beg to differ.
KOPITE: you were supposed to give your batteries a full charge before connecting it to the inverter ( CTEK works well) . Invest in an Inverter that automatically charges your batteries and keeps them in top condition.
I have the 12V version like the one in the link. Great quality and not a rip off price wise:http://www.mantech.co.za/ProductInfo.aspx?Item=372M0024
The Ctek 24v chargers is bloody expensive. What about this one
http://www.bushpower.co.za/products.asp?pid=689
So what if I charge them one by one. Will it work or is it a stupid idea. If I can find a good 24v charger in the range of 1k-2k lemme know guys.budget is really tight.
The link is for a 24V charger @ just over R1000.00
When it detect bateries full it will apply a float charge that is harmless to bateries
You're best off spending money on a good charger.
The mantech ones look like chinese low-mid end stuff to me, looks like they support the charge states, but don't explicitly mention anything else, so may or may not prevent sulphation, and may not be great long term for your battery type.
I'd lean towards something that explicitly talks about sulphation, and pulse charging.
The CTEK and Victron chargers do.
