ODTech
Is anyone farmiliar with the Nitho Drive Pro wheel and pedals?
I bought a set the other day but i'm a little dissapointed in that the pedals function as buttons and not analog or axis which makes playing need for speed shift with traction control off a little tricky.
The pedals are supposed to be analog according to the booklet but when i look at the windows settings it shows as a button. I looked on the manufacturers blog and there was someone from the company supposedly sending out emails with the fix per request but i seem to have been skipped.
Anyone know a trick or fix for this?
