Soft top cleaning kit
Genetic it's generally not advised to use any chemicals on the soft top. Normal sunlight liquid with water is all that should be used to wash it. That's what the manufacturers recommend. These cleaning products are foofies if you ask me.
Interesting, thanks Brenden.
I just checked the owners manual and it says this;
I seriously doubt I'll get any MG cleaning products in SA without importing. Maybe I should be looking for a soft top water repellent instead?
Or maybe just keep it clean?
