telkom adsl line problem
kishan17
I have a 1m/bit line from telkom.i am only getting 64k/bit speeds.(the line was 384k/bit but was so slow i didnt notice the upgrade).I now checked with the adslcheck website and it is supposed to be 1m/bit.I dont think the problem is with the router.I called telkom but this did not help.I think they should do a port reset.Is there anyone here who could do it for me?
PS:here are stats from my netgear dg834 router:
Modem Status Connected
DownStream Connection Speed 64 kbps
UpStream Connection Speed 64 kbps
VPI 8
VCI 35
System Up Time 02:29:08
ADSL Link Downstream Upstream
Connection Speed 64 kbps 64 kbps
Line Attenuation 50.0 db 31.0 db
Noise Margin 24.6 db 18.0 db
