Telkom Fibre issues again
ichigo
Pietermaritzburg
Code:
Reply from 165.143.151.45: bytes=32 time=25ms TTL=245
Reply from 165.143.151.45: bytes=32 time=77ms TTL=245
Reply from 165.143.151.45: bytes=32 time=131ms TTL=245
Reply from 165.143.151.45: bytes=32 time=150ms TTL=245
Reply from 165.143.151.45: bytes=32 time=95ms TTL=245
Reply from 165.143.151.45: bytes=32 time=155ms TTL=245
Reply from 165.143.151.45: bytes=32 time=148ms TTL=245
Reply from 165.143.151.45: bytes=32 time=146ms TTL=245
Reply from 165.143.151.45: bytes=32 time=137ms TTL=245
Reply from 165.143.151.45: bytes=32 time=109ms TTL=245
Request timed out.
Reply from 165.143.151.45: bytes=32 time=124ms TTL=245
Reply from 165.143.151.45: bytes=32 time=65ms TTL=245
Reply from 165.143.151.45: bytes=32 time=57ms TTL=245
Reply from 165.143.151.45: bytes=32 time=61ms TTL=245
Reply from 165.143.151.45: bytes=32 time=29ms TTL=245
Reply from 165.143.151.45: bytes=32 time=36ms TTL=245
Reply from 165.143.151.45: bytes=32 time=81ms TTL=245
Reply from 165.143.151.45: bytes=32 time=128ms TTL=245
Reply from 165.143.151.45: bytes=32 time=111ms TTL=245
Reply from 165.143.151.45: bytes=32 time=117ms TTL=245
Reply from 165.143.151.45: bytes=32 time=107ms TTL=245
Reply from 165.143.151.45: bytes=32 time=119ms TTL=245
Reply from 165.143.151.45: bytes=32 time=93ms TTL=245
Request timed out.
Reply from 165.143.151.45: bytes=32 time=96ms TTL=245
Reply from 165.143.151.45: bytes=32 time=91ms TTL=245
Reply from 165.143.151.45: bytes=32 time=92ms TTL=245
Reply from 165.143.151.45: bytes=32 time=110ms TTL=245
Reply from 165.143.151.45: bytes=32 time=112ms TTL=245
Reply from 165.143.151.45: bytes=32 time=133ms TTL=245
Reply from 165.143.151.45: bytes=32 time=113ms TTL=245
Reply from 165.143.151.45: bytes=32 time=130ms TTL=245
Reply from 165.143.151.45: bytes=32 time=132ms TTL=245
Reply from 165.143.151.45: bytes=32 time=116ms TTL=245
Ping statistics for 165.143.151.45:
    Packets: Sent = 124, Received = 122, Lost = 2 (1% loss),
Approximate round trip times in milli-seconds:
    Minimum = 16ms, Maximum = 155ms, Average = 48ms
Is this the fibre line causing this or Telkom account, ping tested to telkom.co.za and games are laggy because of this problem which are hosted overseas.
Code:
PING 165.143.151.45 (165.143.151.45): 56 data bytes
64 bytes from 165.143.151.45: icmp_seq=0 ttl=250 time=5.046 ms
64 bytes from 165.143.151.45: icmp_seq=1 ttl=250 time=4.890 ms
64 bytes from 165.143.151.45: icmp_seq=2 ttl=250 time=8.518 ms
64 bytes from 165.143.151.45: icmp_seq=3 ttl=250 time=5.062 ms
64 bytes from 165.143.151.45: icmp_seq=4 ttl=250 time=7.870 ms
64 bytes from 165.143.151.45: icmp_seq=5 ttl=250 time=6.106 ms
64 bytes from 165.143.151.45: icmp_seq=6 ttl=250 time=4.959 ms
64 bytes from 165.143.151.45: icmp_seq=7 ttl=250 time=4.847 ms
64 bytes from 165.143.151.45: icmp_seq=8 ttl=250 time=5.064 ms
64 bytes from 165.143.151.45: icmp_seq=9 ttl=250 time=4.927 ms
64 bytes from 165.143.151.45: icmp_seq=10 ttl=250 time=4.771 ms
64 bytes from 165.143.151.45: icmp_seq=11 ttl=250 time=5.218 ms
64 bytes from 165.143.151.45: icmp_seq=12 ttl=250 time=6.613 ms
64 bytes from 165.143.151.45: icmp_seq=13 ttl=250 time=4.910 ms
64 bytes from 165.143.151.45: icmp_seq=14 ttl=250 time=4.775 ms
64 bytes from 165.143.151.45: icmp_seq=15 ttl=250 time=5.809 ms
Code:
hmm crazy high MS, was that with a Telkom account?
What was weird is that yesterday I restarted both the router and Nokia box and it worked the whole of last night until this morning when it started going bad again.
Code:
Request timed out.
Request timed out.
Ping your router as well. Then do a ping test to mybroadband.co.za at the same time.
EDIT:
Code:
Pinging 165.143.151.45 with 32 bytes of data:
Reply from 165.143.151.45: bytes=32 time=47ms TTL=242
Reply from 165.143.151.45: bytes=32 time=48ms TTL=242
Reply from 165.143.151.45: bytes=32 time=67ms TTL=242
Reply from 165.143.151.45: bytes=32 time=52ms TTL=242
Reply from 165.143.151.45: bytes=32 time=53ms TTL=242
Reply from 165.143.151.45: bytes=32 time=54ms TTL=242
Reply from 165.143.151.45: bytes=32 time=59ms TTL=242
Reply from 165.143.151.45: bytes=32 time=64ms TTL=242
Reply from 165.143.151.45: bytes=32 time=50ms TTL=242
Reply from 165.143.151.45: bytes=32 time=51ms TTL=242
Reply from 165.143.151.45: bytes=32 time=164ms TTL=242
Reply from 165.143.151.45: bytes=32 time=62ms TTL=242
Reply from 165.143.151.45: bytes=32 time=73ms TTL=242
Reply from 165.143.151.45: bytes=32 time=55ms TTL=242
    Packets: Sent = 34, Received = 34, Lost = 0 (0% loss),
    Minimum = 47ms, Maximum = 164ms, Average = 55ms
Code:
Tracing route to www.telkom.co.za [165.143.151.45]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  ARCHER_D5 [192.168.0.1]
  2     *        *        *     Request timed out.
  3    23 ms    24 ms    23 ms  196.38.75.70
  4    23 ms    24 ms    22 ms  196.38.75.69
  5    25 ms    24 ms    25 ms  196.35.115.128
  6    24 ms    24 ms    24 ms  mi-za-cpt-p7-te0-0-0-0.ip.isnet.net [168.209.6.12]
  7    23 ms    24 ms    23 ms  168.209.2.130
  8    24 ms    24 ms    24 ms  196-10-140-128.ixp.capetown [196.10.140.128]
  9    24 ms    23 ms    24 ms  196.43.25.205
 10    49 ms    49 ms    49 ms  nbsc-ip-er-1-gig-6-1-0.telkom-ipnet.co.za [196.43.51.74]
 11    80 ms    54 ms    54 ms  telkom-sa-tienet-gw.telkom-ipnet.co.za [196.25.10.42]
 12    49 ms    55 ms    58 ms  198.54.206.73
 13    48 ms    48 ms    53 ms  www.telkom.co.za [165.143.151.45]
Trace complete.
EDIT:
Code:
Code:
Trace complete.
Thanks will do that and edit the post, just lost connection again when I tried to reply :p.
Code:
Pinging *.*.*.* with 32 bytes of data:
Reply from *.*.*.*: bytes=32 time<1ms TTL=64
Ping statistics for *.*.*.*:
    Packets: Sent = 68, Received = 68, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
I edited out my router IP address
What was weird is that yesterday I restarted both the router and Nokia box and it worked the whole of last night until this morning again it started going bad again.
Its not high at all, note the decimal point (.) meaning if its 5.046MS its 0.005046 seconds.
Rounding it all off -> 5MS
This is with bitco fibre.
Code:
Pinging mybroadband.co.za [104.20.9.169] with 32 bytes of data:
Reply from 104.20.9.169: bytes=32 time=17ms TTL=56
Reply from 104.20.9.169: bytes=32 time=18ms TTL=56
Reply from 104.20.9.169: bytes=32 time=19ms TTL=56
Request timed out.
Reply from 104.20.9.169: bytes=32 time=16ms TTL=56
Reply from 104.20.9.169: bytes=32 time=20ms TTL=56
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 104.20.9.169:
    Packets: Sent = 226, Received = 220, Lost = 6 (2% loss),
    Minimum = 16ms, Maximum = 20ms, Average = 17ms
Took a while to show up, but it did eventually.
Character limit exceeded so had to remove some of it :p
Oops I missed that, read it as 5k lol
Code:
You know that the router IP doesn't matter, it's limited to your local network?
You're on OpenServe, try a competitor's data package, just to check if it's Telkom ISP and not OpenServe.
Are there any trial accounts available or a way to use my 1 gb free Afrihost account, which doesn't seem to login when I try adding it to the router.
What do you mean it doesn't seem to log in? Are you sure it's still valid?
The details should work the same as any other OpenServe (dsl) connection.
WebAfrica also has a 1GB one: https://www.webafrica.co.za/home/adsl/ , think Axxess as well.
I used Afrihost fine before I change to Fibre and it says active in my clientzone, just says connecting in router status.
I also have an Axxess account which I haven't tried yet.
That's strange. As far as I was aware you could use any DSL capped account on OpenServe's fiber capped account, ISP side there's no difference as they both go through IPC.
Can't remember my axxess details, but busy trying to find it so I can test it with it too.
Edit: Axxess worked so will see :D. I do have 3 Afrihost which I used on different numbers so maybe I was using the wrong one, going to try a different account next time.
Well if I can use Axxess and works fine then I at least got a backup account and need to hope that the ISP gets fixed :p.
Code:
Pinging mybroadband.co.za [104.20.10.169] with 32 bytes of data:
Reply from 104.20.10.169: bytes=32 time=17ms TTL=58
Reply from 104.20.10.169: bytes=32 time=20ms TTL=58
Reply from 104.20.10.169: bytes=32 time=25ms TTL=58
Reply from 104.20.10.169: bytes=32 time=23ms TTL=58
Reply from 104.20.10.169: bytes=32 time=19ms TTL=58
Reply from 104.20.10.169: bytes=32 time=18ms TTL=58
Reply from 104.20.10.169: bytes=32 time=21ms TTL=58
Reply from 104.20.10.169: bytes=32 time=57ms TTL=58
Ping statistics for 104.20.10.169:
    Packets: Sent = 271, Received = 271, Lost = 0 (0% loss),
    Minimum = 17ms, Maximum = 57ms, Average = 18ms
Code:
Telkom
    Packets: Sent = 238, Received = 238, Lost = 0 (0% loss),
    Minimum = 19ms, Maximum = 24ms, Average = 21ms
Axxess results
Hmm retested Telkom now and it's pretty much the same right now with no problems guess I have to wait for the issue to show again.
