Telkom LTE Speed Problems dropped from 50mbs to 8mbs
DIE_POEF
Anyone here on Telkom LTE? Recently my speed has dropped from 30-50mbs to if I'm luck 7 - 20mbs.
Last night tested all my equipment and suspected that my Poynting Dual Polarised High Gain LTE Antenna may be defective. After testing, it wasn't, but what i did discover is that using my bunny ear aerials gets me better up and down then my R1000 bucks booster which was working fine till recently.
I am going to try and roll back my Huawei B315s router tonight to see if there is a difference.
Is there anyone that knows anything about this? and why my booster wouldn't work anymore on new update?
The only 2 things i can think of is:
The software update on router somehow made my Antenna absolute
Telkom changed something that made the Antenna absolute
Did you check the settings perhaps it changed which port to use either auto on for antenna or auto on for internal?
Yes checked setting, played around with it, the works still the same
pointed antenna to different locations with no win, my friend in edenvale has the same where the antenna has no effect, he also gets better signal just using the rabbit ears that comes with the router
my router has 4 bars of signal now but i used to get 50mb on 3 bars
Telkom recently activated the 1800MHZ band which isnt really great. You may be connected to an antenna sector that is 1800MHZ instead of the 2300MHZ. Also, I noticed that my speeds were very bad after the software update despite having very good signal readings. Rolling back to factory defaults solved the problem for me.
Having a similar problem. I was using an XPOL-6 external antenna and the signal quality dropped dramatically during the last few days. I also now get a better signal without the antenna, or with an XPOL-2 that connects to a different tower.
I am wondering if the 2300Mhz signal on some towers has been negatively affected by Telkom turning on LTE for 1800MHz?
i will reset my router tonight and see what happens.
how do i see the mhz of the signal, i found a huawei testing software which i will also be trying to figure out tonight.
i have asked the manufactures of the antenna and they have no idea whats going on...
logically this doesn't make sense how can the bunny ears get a better signal than the antenna
how did you roll back? do you have a guide?
Okay im annoyed now. Since this weekend the tower I connect to seems to have disappeared
Really tried everything. Moved the antenna on the roof. Took modem around house and played with the bunny antennas. Factory reset.
Gone from 4 bars down to 2 bars. 40mb to 6mb. Any advice would be welcome..
http://mybroadband.co.za/vb/showthread.php/797784-Degrading-Telkom-LTE-Uncapped-speeds
Advice,
Make peace with it, you can stand on your head and fluit Jan pierewiet deur jou hol, Telkom will not resolve this.
5bar signal, line of sight, toti
Telkom feel nothing.
edit:
this is my result this morning and typical of midnght hours and during the day speeds.
In the evenings though the service morphs into an unusable state as per 1st image.
The antenna is absolutely useless now, i will be testing with a capped sim and a older version of the router i have to see if the account is capped or is it because of the routers software.
If this doesnt work it means its telkom!
WTF
RSRP: -99dBm
SINR: 0dB
The external ant. went from 4 bars to 2 bars, replaced the bunny ears and still on 2 bars but from 10mbs to 25mbs+-
I finally discovered how to force set the network band on the B315 using the toolbox.
go to /api/net/net-mode
replace
<request>
<NetworkMode>03</NetworkMode>
<NetworkBand>3FFFFFFF</NetworkBand>
<LTEBand>7FFFFFFFFFFFFFFF</LTEBand>
</request>
with
<request>
<NetworkBand>8000000000</NetworkBand>
<LTEBand>8000000000</LTEBand>
</request>
and write to API
Your modem will connect only to 2300MHz base stations.
replace
<request>
</request>
with
<request>
</request>
and write to API
Thank you! Saved me days of frustration having to try explain this to Telkom support :) Only problem now - I need two LTE routers as the 1800Mhz band gives an awesome upload speed of 10Mbps vs the 3 or 4 I get from 2300Mhz :/
Also - latency is on 1800 is 10ms less than latency on the 2300Mhz band :/
digitalp you are the man!!!! i dont care about the little higher latency or upload speeds!!!! After struggling for months you found the solution!!
