Hi guys, I came here to hopefully find some answers.
I have fibre 50mbps up and down at home.
I use an Asus Rt-ac88u as my router.
I used a Netgear WN2000RPT range extender and it worked fine. It gave me speeds of 38mbps via extender. Now a month later nothing can connect to the Netgear WN2000RPT.
Just purchased an Asus Rp-ac52 range extender. Now it only gives me 10-12mbps via extender.
Is there Netgear just a beast compare to the Asus or am I doing something wrong.
Also did a complete reset on Netgear. Setup from scratch, still no luck connecting any device to the Netgear extender. I think it had many years of service and decided to tap out.
Thanks in advance guys.
Cheers
Cheers
