Help in finding the right MiFi modem
TFTC
I am looking for a MiFi modem with optional LAN input so that I can create a WiFi network from either my SIM card (not 3G dongle) or my wired Internet connect. Does such a device exist? All I'm seeing are 3G routers with Ethernet ports but not not dongle-less MiFi with optional LAN input. Thanks.
3G routers usually have lan out ports, not sure why you want internet ports, unless you are aiming for 3G failover.
http://vkom.co.za/Vkom_3G_351W_datasheet.html
Do do need a 3g dongle but this thingy got a lan port and it creates a wireless network for up to 8 devices. The rechargeable battery supposedly last 4 hours. if battery flat it can be run from PC USB port.
Good idea for ASUS Nexus 7" tablet for portable Internet.
Here are the Vodacom supplied/supported devices ...
LTE compatible devices
Product Type Manufacturer Model
Modem Huawei E398
Modem ZTE K5006 (Available late October)
Modem Huawei K5005
Modem Alcatel L100V
Router Huawei R210
Router Huawei B2000
Handset Samsung GS3 LTE (Available November)
Handset Samsung Note 2 LTE (Available November)
Handset Nokia 920 (Available November)
Handset Nokia 820
Tablet Samsung 10.1 LTE (Available November)
