HELP, Local Usage is 0.0MB?
lylcc
Blended Usage for June
Uploaded 391.5225 MB
Downloaded 3.6103 GB
Combined Total 3.9926 GB
TopUp Purchased for June 0 GB
Blended Current Active Sessions
Connection 1 5.1256 MB Last refreshed @16:18
Local Usage for June
Uploaded 0.0 MB
Downloaded 0.0 MB
Combined Total 0.0 MB
Local Current Active Sessions
No Local Active Sessions
I play local online game and visit local web ,but why the Local Usage=0.0MB ? It's Telkom 4G account ~someone could explain thx!
It works like this:
You first use up the Blended (Local and International) portion of the account, 4GB, and then you get capped sometime after reaching it. Only then does it start to act as a local only account and then you will see that it'll start to show some stats in the local section.
So the first +-4GB of usage, even if you Just surf locally for that 4GB, gets subtracted from your cap. After you get capped, it is a normal local only account. :)
/me ninjas lylcc
/me greets the ninja'ed lylcc
Welcome to the MyADSL Forums! :D
Any usage first goes against you international *yadayada* and once you're capped you will only then be put on local *yadayadayada*.
Someone should sticky a thread explaining this.
//Welcome
It works like this:
/me ninjas lylcc
thank you very very much for this particular answer! but how can it work like this ~~disappoint!
