VDSL upload speed (higher than expected?)
Strange
Has Telkom/Openserve recently bumped up the upload speed on VDSL? I am syncing at 20/5 on a new MSAN that was activated about a week ago.
So my Broadcom based Zyxel syncs at 4Mbps up and my Mediatek based Trendnet at 5Mbps up.
By pasting text I could just make up? Anyways earlier today I asked CrystalWeb to check some things on my line. From that support chat:
(11:26:38 AM) Support Warrior: currentUploadSpeedKb: 5112
(11:26:51 AM) Support Warrior: currentDownloadSpeedKb: 20476
(I saw the same on the modem web interface)
You can post a screenshot and speed test.
Also I realised I might have sounded hostile, that's not the case, I just want to see it.
http://beta.speedtest.net/result/6663399992
Taking and cropping a screenshot on Windows is painful, so here is a copy paste from Trendnet modem:
Downstream Upstream
SNR Margin (0.1dB): 30.9 6.2
Attenuation (0.1dB): 10.2 2.4
Output Power (dBm): 12.7 -9.8
Attainable Rate (Kbps): 114504 5672
Rate (Kbps): 20479 5112
D (interleave depth): 2733 64
Delay (msec): 0 0
Data Counter: 0 Clear 0 Clear
DownstreamUpstream
SNR Margin (0.1dB):30.96.2
Attenuation (0.1dB):10.22.4
Output Power (dBm):12.7-9.8
Attainable Rate (Kbps):1145045672
Rate (Kbps):204795112
D (interleave depth):273364
Delay (msec):00
Data Counter:0 Clear0 Clear
Greenshot.
Or the built-in Snipping Tool.
Eh, sure, but text will have to do for now. I will post some stats from the Broadcom based modem over the weekend.
Getting back on topic, any other VDSL users seeing anything similar?
I now get 10mb upload on my 40mb line. International download is still dog**** slow. (International upload full speed)
Interesting. Can you post your line stats? Will be interesting to see what attenuation/SNR looks like on the upstream side.
So I upgraded to 40 Mbps:
SNR Margin (0.1dB): 23.0 6.4
Output Power (dBm): 13.5 -12.5
Attainable Rate (Kbps): 134276 9390
Rate (Kbps): 40959 8964
D (interleave depth): 1554 81
Delay (msec): 0 0
http://beta.speedtest.net/result/6667650558
The new upload speeds are quite nice.
