WARNING Vodacom 4G/LTE Data drain
mgriffs
I just wanted to share a warning to other Vodacom users about a fairly common issue:
Summary:
- I twice experienced a full data and airtime drain of my phone - I lost everything (R110 and 350Mb) in a matter of hours.
- A technician at Vodacom turned off my 4G and changed my Settings as follows:
Settings: Cellular: Cellular Data Network: Cellular Data: APN to "internet" instead of "lte.vodacom.za”.
- He showed me how he himself didn't use the LTE network because of the problem, having had it occur to him too.
- Vodacom of course refuse to take responsibility and only gave me a partial refund along with some fairly sarcastic and rude customer service.
Details:
On the last Sunday of the month I found myself suddenly out of both data and airtime (having had approximately R60 and 100Mb left). I bought some extra and it too ran out almost instantly (20-30minutes). I only now received the notification SMS’s that I was out of data and would be charged out of bundle rates - now that it was all gone before I could even notice and do something about it. Realising there was a problem I went to the nearest Vodacom (Point Mall in Sea Point). They looked at all my settings thinking I had Updates or something silly on which was draining all my data. I of course didn’t as I am well aware of what uses data on a phone. All of the staff available looked at my phone and they reckoned everything should be fine so I topped up again with just R12 as a test. Within minutes my airtime had gone. Stumped they told me to see the technician at the waterfront branch which I planned to do the next morning. When I woke up I decided to check one more time and loaded R5. It didn’t move and used only the minimal usual amount when I used the internet. Everything seemed to inexplicably work again.
8 days later the same thing happened again but this time, as it is early in the month, it drained my entire contract. Again I received the messages well after both my data and all of my airtime had been used (uChoose Flexi 110 comes with R110 and 350Mb data which I had hardly touched so early in the month). This time I want to Claremont and spoke to a technician, Rashaad. He immediately recognised the problem and tried to explain it. Apparently it’s due to using Vodacom’s much advertised 4G network, but that there is a technical problem that occurs when it tries to reach the towers using the LTE network, and uses large chunks of data for nothing, just trying to make contact. When I say large chunks - it had used all of my 350Mb in a few hours (I had checked my balance the previous morning and it was almost untouched). It was hard to understand exactly how this works and why it only happened those two times, the technician didn’t seem to know, but had had the same problem himself. The solution was to change the settings and NOT USE the 4G network that Vodacom loves to advertise. He showed me how he himself didn’t use 4G, having had the same problem. At this point I was fairly annoyed that the product that they advertise so wildly has a technical fproblem that isn’t the consumers fault and has the ability to drain so much data/airtime. That it’s so bad that even they’re technicians don’t use the 4G network. However, he was trying to help so I accepted the settings changes as they won’t affect me that greatly. The technician also put in a report/request for me to get my airtime back given that it was not my fault it had drained.
The next morning I received the following SMS “Good Day Matthew, we would like to thank you for your enquiry. Please note that the charges that occurred is correct as you did not have an active data bundle. I will refund you as a gesture of Goodwill R157.94. Please note it is your responsibility to manage and monitor you usage not that of Vodacom. Kind Regards, Vodacom Customer Care Michael Van Wyk”. This came from one of Vodacom’s SMS numbers which one can’t reply to and had no contact number to follow up. In the context of my issue it was definitely not that I didn’t have an active data bundle that caused the problem. I did, and not only that but it used all my data and then my airtime before I was SMS’d because it went that quickly. In fact this response is incredibly sarcastic and rude given the fault that occurred and I found it very offensive. I’m well aware of data bundles and out of bundle rates and that was NOT the problem I had.
Given that I only got the warning SMS way after my phone had used all of it’s R110 for data, I also asked if there was a way to prevent one’s phone from switching to using the airtime as data once a data bundle had run out, there appeared to be no way according to the staff.
All of this makes it feel a lot like a scam as Vodacom have an inexplicable error which uses all of one’s data and then airtime as data BEFORE the warning SMS arrives. One then has to top up and spend more money with Vodacom. And even when the technician helped it was only to STOP using their advertised 4G/LTE service as a solution. My money was also then only partially refunded with a very sarcastic and rude SMS to which I can’t reply.
Follow up:
I took to a Vodacom forum to try and raise the issue. Pasting most of the above text.
http://community.vodacom.co.za/t5/Our-Network/4G-LTE-Data-drain/m-p/6690
I was again told "Hi Matthew. We understand the frustration and have looked into this for you. Ref Number S3-8AA3J-J3EAG was assigend and the consultant offered and provided the gesture as mentioned. However, the usage is correct as it did originate on that device and it remains the users responsibility to manage the device and the data usage on that device.”
I responded, reminding them that their technician had told me about the fault being a network error and that he had said I hadn’t done anything wrong. They replied that they would then check with him, but again layed the blame on me. When I replied to this explaining that I was offended and irate that they kept laying the blame on me when their technician had told me directly that it was not my fault- they moderated my comment and deleted it. When I questioned why they moderated my comment and deleted it they just deleted that as well. There was no reason for them to remove it as I was not using any foul language.
4G/LTE Data issue with Vodacom [WARNING]
Summary:
Details:
Follow up:
Ouch, not cool from Vodacom.
How did the incorrect APN settings get loaded to your phone? Surely thats part of the setting they send to the phone?
Afrihost has a habit of sending you notifications if you are not on the right APN for their mobile solution as the APN can sometimes be reset... I suspect that could be an issue somewhere
I don't think the incorrect APN was loaded. I think the OP is saying that the Lte APN, that is on by default if you have a 4G phone, uses more data when trying to connect to the tower. They put the HSDPA/3G APN in manually and that seemed to solve his problem.
I understand that. But if the default APN uses more data, and this default is provided by the service provider they should be liable for the data usage
They probably should be. But considering the amount of 4G phones on Vodacom I haven't really heard of this problem before so I'm not sure how the OP proves this to them.
Thats all a lie, you have an app on your phone thats downloading info in the background, whether it be LTE or 3G the data usage is still due to an app you have on your phone and not the 4G network.
Delete your apps you dont need or manually switch off the data for those apps.
The settings weren't "incorrect" as such and were the ones sent by Vodacom, they are the normal LTE settings. The Technician said there seems to be an error with the network which occassionally occurs. However it seems very scam like that a inexplicable error sometimes steals all your airtime. And the fact that one of Vodacoms head technicians didn't use the 4G network because of the error was very telling!
Indeed, it was the standard APN. However "not using the 4G network" does not seem to be an appropriate solution to me. Never mind their terrible customer care and preventing me from posting on their forums.
The technician at Vodacom knew all about the problem and had changed his own settings to prevent it, and after taking to social media I've had others say they experienced the same thing.
Maybe. Lots of people don't realise that apps running in the background use data and maybe that's what they are experiencing but they assume it's the cause you describe. I haven't really noticed that issue but then again I don't monitor my data that closely.
I'm well aware that an app could have been a problem, and had of course checked my settings, and that was the first thing I re-checked. Vodacom also checked initially and found nothing wrong in my apps and settings.
The senior technician I eventually spoke to told me it was NOT due to an app, and was due to my phone trying to reach the 4G/LTE network. He also showed me his own phone and how it wasn't on 4G because of the known issue. He also logged into their systems and showed me the data usage specifics and how it was just my phone "pinging" the network that was inexplicably using large amounts of data.
So I'm not really sure it's a lie. If their senior technician says so. Are you also a technician?
Nope, but where did you meet this "senior technician"? At a Vodashop?
Again, The technician himself, a senior technician at Vodacom, knew about the error and said it was NOT app related. He himself did not use the 4G/LTE network due to the issue. He ALSO logged into their systems and showed me the detailed data usage.
I'd love to know exactly what the error is caused by but I'm pretty sure if their senior technician knows about it and says it's not an app problem then he's correct.
Unfortunately I did not record my conversation with him.
I'm also not a noob, I wouldn't allow some up to chew through my data, and this also doesn't explain how it randomly happened on two separate occassions, inexplicably, without me changing how I use my phone.
Don't know what phone you have, but on android phones you can setup a warning and a hardcap yourself.
Under Settings > Data Usage. You can set a warning data usage amount with a slider there. And if you tick Set mobile data limit you will get a slider for what amount of data use you want to be hardcapped at by your phone.
Can you access a data log on your phone to specify which app or activity reported the usage? If the usage on your phone is vastly different from what you were charged then the refund is forthcoming. If you share this information on the VC site, make sure to make a screenshot before they delete the post so that you can paste that here.
Summary:
Details:
Follow up:
As it would with an app updating in the background...
