nicroets
Let's get busy. Let's design and build all the infrastructure necessary for the big switch-on on 1/2/05, so that it will run on existing bandwidth. What's needed is :
1. A high-level protocol that will determine the best low-level protocol / codec that 2 phones can use. Does any one know if such a thing already exists ?
2. A server / database to translate 10 digit South African dialling codes to URLs (hostnames and port numbers?). This will allow computer illiterate people to transparently switch to VOIP and PABXs to do least cost routing.
I'm willing to donate a lot of my time to write such a system.
3. Suppliers for
a. WLAN handsets ?
b. VOIP PABXses that plugs in to the LAN ?
<center>MyWireless Tower Distance Calculator
MyTransponder</center>
3. Suppliers for
a. WLAN handsets ?
