I've been messing with RWIN and MTU on my PCs, running online tests etc.
So far all I've managed to do is sort out ICS by decreasing MTU size on all PCs to 1492 (max PPPoE).
RWIN on ICS gateway PC to 32767
(<i>not happy with that figure, but it is based on calculations with MSS of 1452</i>).
I know there are lots of factors that make these settings fairly unique to each of our setups, but what does evryone else find works best[?]
Apart from using RegEdt32 or RegEdit or DrTCP.exe, are there any other utils out there that allow you to change everything all at once[?]
