Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Results 1 to 2 of 2
Thread: Signal Strength Problems: Fluctuations, Weak, None, Disco Lights etc
  1. #1
    Spammer be gone bug spray
    Join Date
    Nov 2004
    A nearby event horizon
    Posts
    13,963
    Exclamation Signal Strength Problems: Fluctuations, Weak, None, Disco Lights etc
    Ok iBursters & Burst-iz, I am creating this new thread specifically to document problems with Signal Strength or lack thereof.
    Please categorise the problem
    (e.g. Fluctuations, Weak, None, Disco Lights etc)
    then mention the base-station(s) that your UT is known to connect to (helpdesk have access to base-station connection info). If there's anything else you can think of that's relevant (like you are or are not using an external antenna - effective 2010+) then mention that as well.
    If this thread gets a reasonable number of posts it could be stickied, but it isn't necessary right now - considering all the other threads that WBS have yet to address to the point where they can be unstuck.
    Thanks.
    Trolls stab you in the back and bleed you dry like mosquitoes, and that's why I don't feed the BBL trolls with any new posts.
  2. #2
    Join Date
    Nov 2004
    Posts
    13,963
    Default
    Code:
         Problem: Weak & Fluctuating Signal 1..3 leds
    Base-station: Bryanston Water Tower
         Started: 2005-02-17 after 15:00
       More info: signal strength was 4..5 leds for most of the day
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
