Dell D830 running XP Pro 64 Bit
MidnightWizard
KZN
For anyone looking for an alternative to upgrading to Win 7
I have XP 64 bit running fine on my D830. ( Although NOT officially supported by DELL )
4Gb Ram -- VLK & SP 2 plus ALL device drivers installed and working 100% including ACHI SATA.
64 bit themes available and running 64bit Firefox.
MS Update works fine as well.
Stable and FAST
Very happy
MW
I love XP 64-bit. The only problems I have encountered are driver support (for 3G and some wireless network cards), and a few applications like Nero which require a different license.
64 bit Applications
If you scratch around on the DELL Drivers page especially for VISTA 64 bit you will find a lot of stuff that can be used.
My INTEL WiFi card is working fine with the native DELL drivers.
Running Google Eath fine -- strangely my GPU is reporting 512Mb memory.
With the latest BIOS upgrade you can run EIGHT Gb memory on the D830
Will get to the other application bridges when I need to cross them.
I assume that with MS 7 there are going to be a lot more applications upgraded to 64 bit.
At the moment running GE I need more and faster bandwidth and an upgrade to a "Draft-n" Wireless access point.
MW
