Hi all is there any way i can align my senao wireless antenna which is on the roof and has definately moved.
Can i get an onscreen signal banner and then up the signal via walkie talkies.
Many thanks.
Many thanks.
If you don't have it already, get Proasm's MySignal. Will do the onscreen signal strength you're looking for. Should not be connected to the network when checking signal strength. Also assuming you're conencted via usb to the modem. Best used with laptop while on the roof![]()
ADSL 4Mb & DG834GT | Ex-Iburst, Ex-Sentech
MYBroadband.co.za - Your electronic condom against those unwanted telecom infections !
Thanks very much for that info and the upload luke,well appreciated.
And of course can take my lappy onto the roof, its via ethernet.
Just trying to get it working now thanks again.
hi how exactly do i use this program,do i have to set up ports and put a username and password in.
Assuming Win XP. No port setup needed.
1. MyWireless modem has to be connected to pc via usb, NOT ethernet You can switch back to ethernet after signal testing
2. Don't know whether MySignal requires user/pass when testing for signal only. If so, give your Sentech user/pass
3. Click the MySignal tab
4. Click the yellow phone icon
5. Signal strength will be displayed
6. Click (red) phone icon when done
If you can't do (1), you're screwed, since MySignal doesn't work over ethernet. Most of the above is from memory, since I'm not connected via usb anymore
Checkout Proasm's MySignal page, for more info
hello
cen sombady help mee i have senao ap 200mw end i have hyperlink
HA2401RTG-1000 1 Watt but problem is i mount amlifire with senao not working
cen sombody help me what need i do tu connect with senao this hyperlink amplifire
thnx
Maybe try the WiFi forum, since it's totally different from MyWireless (this forum), but maybe revisit/rethink/restructure that question of yours before you venture into those forumsOriginally Posted by llukeri
looks like i,m screwed then as its ethernet only,i,ve had a look inside the antenna and the modem is built in to it and thats got an ethernet connection and a power connection,but thanks again luke.
The original MyWireless software CD that came with your modem will show you the basic signal info over Ethernet. Just install the Sentech MyWireless dialer software that came with the PC.
Boom....
Strange, I thought the MyWi modems came with a usb cable standard, ethernet as an optional extra. But, as Rodent said, the standard stuff will also give you an indication, but usb/MySignal is still the best way to test imoOriginally Posted by henrik67
Bookmarks
