Facebook   Twitter    e-mail newsletter    YouTube    RSS Feed    Android App    iPhone and iPad App     BlackBerry App
Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: Serious Laptop problem... please help =(
  1. #31
    Super Grandmaster
    Join Date
    Feb 2005
    Previously this post ->
    Posts
    24,014
    Default
    How is the heat? Modern processor will go into limp mode if the notebook is getting too hot. When it slows down can you hear the fans getting louder?
    Quote Originally Posted by reactor_sa
    ^ fountain of knowledge
  2. #32
    Default
    It does get very hot actually, or to me it feels really hot.. I have a program called CPUID that tells me the tempriture, the minimum is 48, the average value is 54 now and the max is 69 is that normal for a core i7?
    I actually have like a story I can tell you about the company LMR (LetMe[completelyf_ckup]Repair) that I have been fighting with since 22 February and still waiting for damages parts (base cover and LCD screen frame)
    I wonder if there technicians wrecked my hardware?
  3. #33
    Master shakes1's Avatar
    Join Date
    Jun 2010
    Lost and Confused...
    Posts
    971
    Default
    Drop me a PM OP, will try to assist remotely, or pop on by if you're in JHB (on mobile, can't view your location)
  4. #34
    Super Grandmaster
    Join Date
    Feb 2005
    Posts
    24,014
    Default
    Quote Originally Posted by Charlikins101 View Post
    Sorry I should have mentioned you also have other chips that get hot, these can be monitored by apps like HWMonitor (made by the same guys as CPUID)
  5. #35
    Default
    Keep the OEM Windows Disk that came with the laptop, or make a back up and Reinstall Windows.
    Needless to say you should, backup all your important files and programs.
    If that does not solve the problem, it should then be a hardware fault.
    1 Out of 15 times, posted from my Windows 7 Phone, using IE9 or probably a laptop running Windows 8
  6. #36
    Default
    No, but they removed bad sector or other critical disk error (the reson you brought it in) and they didn't check in which condition hard disk is after reapair.
    I quess hard drive received mechanical shock, in result SA is corrupted, or heads are permamently damaged. On some drives SMART would tell us, it is why I asked for SMART report.
  7. #37
    Default
    SAJunky will this program do what you need to see?
    http://hddscan.com
    What you were suggesting before even had me lost.
    "The problem with quotes on the internet is that you can never be certain they are real"-Abraham Lincoln
  8. #38
    Default
    It looks like, it is supposed judging from picture 4 and 6. it is exactly what 2xF4 do in mhdd. I use DOS programs, to not let Windows interfere with disk access. What I need is a summary of delays in each category from 5ms to >500ms, plus bad blocks if any.
    Do you really think SATA drives cannot be tested in DOS programs? Haven't tried with >2TB drives though.
    Re: SMART parameters there are many programs doing it.
    I see program do not require installation, this is good, but GUI hangs mice at times. Not sure how it handles disk errors too. SMART could be better. I use hdat2 (DOS program)
  9. #39
    Default
    Quote Originally Posted by The_Librarian View Post
    Dodgy hard drive is suspect.
    This system have the symptoms of a HDD going south or my name aint Ook.
    Me thinks this too.
    Sorry What!?
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
