endlesslyonline
- Aug 22, 2008
I am a total new on this, so maybe someone can help me out.
I have, well, had a normal box(CRT?) TV in my bedroom, and all of a sudden, it decided to die, everyting is inverted, and the ppl are green
. I have a LCD Full HD (20") TV, that we decided to put in the room for the time being, but here is the thing, we cant see anything on it, the TV is situated in front of the bed, but it is kinda high up, so watching it from that angle, makes everthing on screen dark. I *think* I read somewhere, that plasma has a better "veiwing angles", is this correct? or will the plasma do the same, or can it be because the 20" we have, is a cheaper model, will the more expensive ones do the same?
Lastly, if plasma is the answer, I also recall somewhere, that you dont get "small" plasma's, i dont really want to put in a massive TV in the bedroom. What is the smallest plasma's you get?
in general, which are best (LED/LCD or Plasma), basically using it for SD tvrips that i stream from the xbox
Thanks,
Thanks,
