Does anybody know if the code changed on the DSTV decoder for the advanced setup screens (dish, LNB etc). The code used to be 9949, but after an updated seem to change.![]()
"Anything that is too stupid to be spoken is sung"
- Voltaire (1694-1778, French Historian, Writer)
I had the same problem with it not accepting 9949 - try pulling the plug and resetting it. That worked for me.
"Le mieux est l'ennemi du bien." FM Arouet
"All that is necessary for the triumph of evil is for good men to do nothing." Edmund Burke
"Never argue with an idiot. They drag you down to their level, then beat you with experience" Unknown
It never accepts 9949 for the parental control part for me (PVR-II). But as far as I know it was accepting for setup section.
Give us more bandwidth at reasonable prices
Cool thanks guy's .. I'll try this when I get home tonight !![]()
If you don't have any "extra" channels, look for a setting called restore factory defaults![]()
Soli Deo GloriaBe wise as serpents and harmless as doves,
|FaithBook|Righteousness|DomainCheap|Gecko Stretch Tents|
New Dstv Free Codes On Pas7/10 Please Reply
what?
Do NOT construe anything I type as advice
We're all running on caveman software...
My latest threads
I'm sure PeeknPoke managed to sort this 1 out between August 2006 and now.....
ADSL 4Mb & DG834GT | Ex-Iburst, Ex-Sentech
MYBroadband.co.za - Your electronic condom against those unwanted telecom infections !
Bookmarks
