PVR remote code for Xbox360
Phenom
Hello there, anyone happen to know the DSTV PVR remote control code to make my xbox360 listen to the dstv remote?????:confused:
Any info would be virtually appreciated.
The DSTV PVR's are locked. They not the same as the ones in the USA and UK. I might be wrong
The PRV remotes are somewhat programmable. You can control different devices with the X,Y,Z setting on the dial.
You might have to just go through them all Orangeman until you find the right one . . . if there is a right one.
:eek: serious... how... That would be awesome, I just want to control the TV with it...
Oh and while this no longer has anything to do with the Xbox 360. Does anyone know where I can get a replacement remote?
I tried to find the code to control the xbox from my Sony remotes, alas couldnt find the code :(
Can control everything else though
Thats exactly what we do. We got our spare ones from Ellies - I think they're country wide. Otherwise any multichoice office should have them in stock.
I remember reading on their forum once that they do not supply codes for any product that can be deemed "competition" i.e. DVD entertainment Ssytems etc.
anyway, here's a link to the PVR remote user guide
Someone please help this idiot.
I tried to set my PVR remote to control my TV yesterday and nothing happened.
I changed it to Y3 or whatever, then held shift and then put in a 4 digit code. nothing happened?
