Formatted PC, Help!
NeonNinja
Neon Resident
Neon World
Just formatted my PC. I do not have an Internet connection. I lost another disk with essential programs. Basically I wanted SP2 (I'm on XP), to install it, then install SP3. I don't have a service pack (I have the SP3 executable), even 1. What is the registry hack to make windows think I have SP1 or SP2, so that I can install SP3. Every time I try install SP3 it says I need to update system first.
Thanks.
Thanks.
It won't work. You need to upgrade properly in the correct sequence or you will hose the system.
Some versions are. You can get an SP3 that will update from "bare" XP, but then you also get SPs that have to be used in sequence.
