Difference Between Plasma & LCD
Pearson6
I often get told that LCD is better than Plasma but sometimes read that plasma is better. So now dat its finally time to upgrade I wanna find out which is better.........any suggestions? I"ve always been a Sony type of guy......but then get told that Sony uses Samsung old panels:confused: is that True?
APoc184
It depends what you will be using the screen for.
More info.
APoc184
Then you should go LCD.
Plasma is better when viewing SD content like television.
I got a Plasma because I never play games on it, mainly watch sport over the weekends and about 2 hours of TV during week days.
Mlungu2
If you care about the environment... go for LCD. They use much less energy and dont require the potent green house gas nitrogen trifluoride during production (plasma screens do).
Pearson6
What about LED? I heard they quite good and the best when it comes to energy efficiency
