That tower most likely only supports 2G. I've driven down Garsfontein and when I pass Bashewa I get a 3G signal, and when I get to the R25 (Pretoria Road) I only get a 2G signal. Then driving down the R25 towards Bapsfontein, I only get my 3G signal back when I get to Bapsfontein (R50/Delmas Road).
So most likely they still need to upgrade that Welbekend tower to support 3G.
If you have a 3G yagi, you could try pointing it towards Bashewa, in a north westerly direction.
Hi nuyork,
thanks for the response and feedback. I have had a look again at the Vodacom Coverage map and now that you have mentioned the Bashewa Tower it appears that this could be true. Data coverage is up to the Bashewa side of the R25. If hope Vodacom can also confirm that the Welbekend Tower is not 3G enabled. I will go out there again and measure the Signal with a Yagi pointing toward the Bashewa Tower - will provide feedback once this is complete.
Thanks!
